I am currently working with an organization in Puerto rico repairing concrete roofs for homes damaged in hurricane maria. Many homes in the area I am working in do not have running water, and I am trying to find a solution towards being able to pressure wash and clean the roofs on the areas to open up the roof and begin all necessary repairs. I am looking at purchasing a water tank, and I was wondering if it would work to use a pressure washer on a roof, at most 8 feet above the tank, to clean the roof, and if said circumstances would create enough pressure to run the pressure washer, and for how long. I am looking at getting either a 400 or 500 gallon tank, and can most likely not get a water pump with available resources. The pressure washer I am using is “DeWalt Professional 3200 psi (Gas - Cold Water) Pressure Washer w/ Honda Engine & Cat Pump - DXPW…” any other suggestions would be incredibly helpful.
Thats a direct drive so prob not and why would you put a pressure washer on a roof
Thank you, and short hoses as well as low access to the areas around the homes make it so that we have to bring it all the way up
Id get longer hoses if possible and then put the pump bellow the water line (ether by keeping the tank always half full or putting the tank above the washer with a pallet or just the landscape around you.) God speed
Got any photos of worksite?
