Hey guys, so I have started on my first ever business and went to the route of pressure washing. I had a dewalt 2.5 gpm 3600 psi machine that I already had and bought an xjet for it to get started. I got a job at a well known restaurant in my area that I work at, and my dewalt surface cleaner broke mid job, before I got to finish the entire thing (was actually the third one after getting multiple replacements for free, they keep breaking. It is meant for that machine as well, just a terrible product). How should I complete the job? Any well made surface cleaner will not fit my machine and just need advice here.
Better machine and surface cleaner?
If it were me I would try to get commercial grade equipment to work with, it will be a headache if you don’t. I applaud your hustle though, we all start somewhere. Just ask yourself how do I want to start. Much success!
You could wand it if you have to, if it’s not too big of an area.
Its a pretty decent sized area.I I’m 16 and haven’t had a job for long so I only have around 2,000 saved up and preferably wouldn’t want to spend all of it, but would be willing to if it was absolutely necessary. What would be a good setup for me to start out with?
Minimum 4 gpm but preferably at least 5.5 gpm, surface cleaner a whisper wash classic or whisper wash ultra clean.
I use heated water for restaurant stuff but can be done with cold water machine, just need to use the right chemicals. Hot would be better though for the grease, etc…
@CLille check out your local power equipment rental places. There’s likely a Sunbelt Rentals, United Rentals, and more not far from you. But be sure to check the smaller local companies as well. They should be able to hook you up with a decent machine and surface cleaner to rent, whether it be by the half day, day, week, etc. Try out a unit and see how it works for you. Not as efficient as you’d like, try renting a different combination. This would at least get the job done and you paid. You might not make any profit - depending on how you bid the job - but it could help you save face with the customer as well as open your eyes to more efficient equipment. Good luck with it!
Where are you located?
Florida. Port Charlotte area
That is a very good idea actually. Thank you!
