Pressure washer build analysis
Is this build gonna get me 5.5 GPM at 3000 PSI? Based on the specs it seems like it would, but I thought I’d check with you all to see what your thoughts are. Obviously this is a budget build so it’s not gonna be super high grade, but for $1100 is this gonna do what it says it will?
Pump: $285; • Canpump CF 3257 G 3200 psi @ 5.7 US gpm Pump
Engine: $380; • Predator 13 HP (420 cc) Gas Engine
Unloader valve: $50; • Canpump Unloader Valve 4000 psi @ 6.6 US gpm Easy Start
Frame: $120; Pressure Washer Skid Mount Plate Frame, Powder Coated Steel with Rubber Feet
Hose / Fittings / Quick Connects: $40; RYOBI 7‑Piece Pressure Washer Quick Connect Upgrade Kit
Pressure washer Gun: $35; Pressure-Pro 4000 PSI 3 ft. Insulated Pressure Washer Gun Lance Assembly with 3/8in. Quick Connect Coupler
Pressure Hose: 3/8 $40; BluShield Rubber Pressure Washing Single Wire Hose 3/8" X 50’ with Coupler & Plug-Grey (4000:16000 PSI)
Garden Hose: $25; GREENWOOD 50 ft. x 3/4 in. Contractor Garden Hose
In-line water filter: $15; PATIKIL 3/4 Inch Male In-Line Strainer with 100 Mesh Stainless Steel Filter Screen Water Pump Filter
Nozzles: $20; 105087 Spray Nozzles - 5 Pack - 5.5 - General Pump
Thermal relief valve: $7; MTM Hydro 1/4" Thermal Relief Valve
Surface cleaner: $90; 16.5" Pressure Washer Surface Cleaner, Stainless Steel Pressure Washer Attachments with 4 Wheels, 4000 Max PSI, 1/4 Quick Connector, 2 Spray Nozzles, 2 Extended Wands for Concrete, Patio, Deck
Are you going to have a buffer tank for this setup? 5.5gpm is pushing it for a lot of water supplies.
components I personally would invest a little more in:
Gear (or belt) drive pump so you can pull from a buffer
Flow-actuated unloader, like the zK1 for less strain
Suttner 2315 gun
to your initial question, I would plan on 2500-2700 psi out of that setup, but you might get 3000 ok.
No, I was not planning to use a buffer tank for this setup. My budget is around $1200 (I’m aware it’s a tight budget) and I’m seeing what my best option is for that range
This post is similar to another post, but has updated parts…
This build costs $867 WITH a surface cleaner. Are these specs actually gonna get me 5.5 GPM at 3000 PSI? I’ve checked with chat gpt and it says that it should work well (I just gotta properly mount it to a wagon I have).
Pressure washer build:
Engine: $140; 4-Stroke 420cc 15HP OHV Horizontal Shaft Gas Engine Recoil Start Go Kart Motor. 4-Stroke 420cc 15HP OHV Horizontal Shaft Gas Engine Recoil Start Go Kart Motor | eBay
Frame: $30; Hillman 24-in x 24-in Steel Solid Sheet Metal
Pressure washer Gun: $35;Pressure-Pro 4000 PSI 3 ft. Insulated Pressure Washer Gun Lance Assembly with 3/8in. Quick Connect Coupler
Surface cleaner: $180; Costway 20" Pressure Washer Surface Cleaner Stainless Steel Power Cleaner Attachment
More then likely, once you factor in connections/angles, hose length, friction loss, etc you will end up with less.
Canpump isn’t highly regarded from what I’ve seen, cheaper internals hence cheaper price… if you do go this route, start saving to replace with quality brands.
Again, no-name brand… I’d plan on saving up and replace it sooner then later so it doesn’t leave you stranded on a job. Also verify the shaft size, I didn’t see the spec on the listing, but make sure it’s compatible with your pump size.
Again canpump (also the pump you are looking at already has an unloader on it)… a VRT-3 is the same price, still not great, but if you are strapped for cash…
Way too thin… you want at least 1/4”, more is better
You are way underestimating the budget for this
It’ll work for now
50’ isn’t a lot, I’d want at least 100ft, if the machine was on a dolly. The way I’m envisioning your skid now it’s not very mobile… If you aren’t going to be moving it around, 200 feet is the minimum I use on each job.
Again, 50 feet seems too short to me… parked at the curb, most jobs take 75+ feet at least, but again 200 feet on the reel.
You’ll want closer to 50 mesh
I’d verify the actual GPM of whatever pump you get before buying a pack… also might be a better idea to buy higher quality, but only the sizes and spray patterns you need. I have never used a red, black, or white tip.
I’ve never used one, not saying thats right or wrong, but it’s money saved.
Some people like casters, others don’t… like the other cheaper options, I’d plan on saving for a replacement.
So… will the setup work? It might, but I think you’re underestimating both what you’ll need and how quickly the costs can add up. I understand wanting to save money, but going with the cheapest or no-name brands can end up costing more in the long run. Buy once, cry once.
The biggest issue I see in your plan is the lack of a buffer tank. Depending on where you’re located, most municipal supplies deliver around 4–5 GPM at the spigot. If someone in the house is running laundry, dishes, or taking a shower, that flow rate can drop off quickly. For anything above 5 GPM, you should really consider adding at least a small buffer tank, something in the 15–20 gallon range could work, but it’s worth testing your actual flow rate first.
Related to that, your setup doesn’t appear to be mobile, and your hose runs are quite short. Even without knowing your exact location, it’s hard to imagine 50 feet of both pressure and supply hose being enough to efficiently move around an entire house, especially if the unit itself isn’t mounted on something portable.
Lastly, I’m not clear on how you’re planning to apply chemicals. That piece seems to be missing from the setup, and it’s a pretty important part of the overall system.
I’d suggest lining up a few jobs first and renting the equipment you need from a big box store for the day. It’ll run you about $150, and you should be able to easily make that and then some in a day.
That approach lets you build up some cash while also getting hands-on experience with what works and what doesn’t. Once you’ve done a few jobs, you’ll have a much better feel for the type of setup you actually need, and you’ll be in a position to invest in quality, professional-grade equipment instead of guessing upfront. Also a lot lower risk incase you find this isn’t the business for you.
This is what I did starting out. I was able to prove to myself that there was an actual market and money to be made in house washing. I spent less than $100 with PressureTek to get a downstream injector, a decent gun, spray nozzles, and some soap. I later bought extra lengths of pressure hose as what the rental place provided was limited, and a blown out hose can wreck your day if you’re out in the middle of nowhere.
Also remember, not all debt is bad. If you are investing in proper equipment to run a profitable business, credit can sometimes be the smartest way to get there. (And the little bit of interest you’ll pay is also tax deductible.) Once I had done enough jobs to know I wanted to get more serious and buy real equipment, I put around $2500 on a credit card and paid it off in a couple of months. A few years after that, I decided to build a whole truck rig. Financed the truck through a local Credit Union, and put most of the new equipment on a card (I think I spent around $12k initially on that setup; wrote the whole thing off under Section 179 and ended up saving a bundle of money on taxes that year). Paid the card off within 6 months and paid off the truck loan the summer of 2024. I’m now debt free and in a financial position that I don’t need to use credit for even major repairs.
Exactly this. It’s honestly the smartest way to approach it and if I could go back and start over, it’s exactly what I’d do. Over the years, I’ve bought so many pieces of equipment and tools just to replace the cheaper options that either broke or weren’t efficient enough. If I knew then what I know now, I would’ve saved a lot of money but at the same time, that trial-and-error process helped me figure out what actually works best for my setup and workflow.
The business is 100% debt-free. I still use a credit card for purchases to earn cash back, but I always pay off the full balance every month.
You guys gave him a solid breakdown. As the forum has said a bazillion times, buy once cry once.
There is an old adage that comes to mind; it takes money to make money. Not saying you can’t start off small, but at least buy decent starter stuff and don’t forget the insurance. One ruined anything can be thousands of dollars.
I went the cheap way at first. And now I have a lot of pieces sitting in the garage on a shelf not making money. That if I had bought a little better I would have saved about 1/3 of the replacements not including the time loss. If I was still using what I started with verse what I have now. I could have done 3 or 4 houses instead of two that I was doing then. Remember time is money. Most of us do not bid jobs by time it’s by the job.
