My heater quit working the other day. I found I was getting no power from the plug on the generator. I used a drop cord and plugged into house outlet and worked fine. Is there an internal fuse on these generators? Its only 10 months old. I would hope that the generator has not already gone bad. Is there other ways to test as i’m not too mechanically inclined?
I am having the same issue. Mine actually worked and I had to replace the fuel pump on the burner. After replacing everything I fired it all up and had no generator. What did you end up finding out with yours?
There should be a internal fuse on it that needs replaced, take a pic if you can so I can tell you were its at
