Are you guys sayin you can through a 8 gpm pump on these puppies?
Yep. There are a couple of threads on it.
Yes the 22hp model will run an 8gpm 3k psi max.
I have a 8/2500 udor gear drive and love it! Run it hard on hot days and she sings all day!
Hell yea
Guys, youāre talking about 2 house washes for the difference in a Honda. Thatās one afternoonās work.
is that a cart they are mounted on?
Does the predator engine have the same thread size for the oil drain plug an a Honda? I want to add an oil drain tube to make my life a little easier.
Guys I truly donāt want to rain on anyoneās parade and I like HF freight as much as the next guy, and I know some of you use these successfully, but when you look at it longer term, for $700 difference you can buy a Honda, on a piece of equipment that will last for years and years. Thatās truly 1 days work and you donāt have to buy extended warranties, swap out the fuel pump, the time it takes to take it back even if you do have a warranty and rebuild your setup, etc. I just donāt understand.
Buy the right equipment if youāre making a living doing this. Or donāt and break down more often. The price difference isnāt worth the headache and/or worry factor.
I totally agree, just get proven good equipment to be useful for years to come. It will make you money.
Iām doing it more for fun. I donāt have room on my trailer for more machines and itās a single axle so I am limited on the buffer size. Iām gonna put in the bed of my truck. Unfortunately it wonāt last long because of the salt air, everything exposed to the elements rusts to hell. Iām not blowing money on a $4k plus machine when I can build one for $2k. From what Iāve read online it seems like 50/50 if it will last.
Can anyone tell me if the Honda drain plug will work on a Predator?
Lookup predator vtwin motor pdf. It should tell you the plug size. If do it but I have too much downloads of other stuff Iāve looked up, need to purge.
Will do. Iāve been Googling the heck out of it and canāt find an answer.
Iāve had Chinese lifan engines in my company for years, great little engines. Actual engine blocks last about the same as my genuine GX390ās. There isnāt much to these engines service them like everything else and they will last. The v twins might be a different story.
The Honda GX390 and Predator 670 have the same size oil drain plug.
