Predator 670 replacement key
Paging @SchertzServicesLLC and other predator users. Have any luck finding a replacement key that works? I lost my pair and I’ve tried three different “universal” mower keys from Lowe’s and TSC with no luck.
Harbor freight doesnt sell them?
Nope. How silly is that?
Heck ya. Good luck. I’m sure someone will know.
Man, that’s a tough one! Mine is zip tied to the motor and hasn’t been out since it was first started new. Did it come with two?
Yep and I lost both of them
Never separated them.
Flathead screw driver won’t work?
Box and keys for 40 bucks
It’s probably the easiest ignition to pick if you need it now. You tube …probably has two tumblers
If you don’t find a solution by friday send me your address and I’ll mail you my spare.
Use this to look for a similar.
That did it. Thanks.
Looks just like a Honda cut.
northern should have them in their “shop”.
Well it’s a Honda clone is what I’m told!
Long as you don’t use them 2 different motors in the same sentence, the world will still turn correctly …@SchertzServicesLLC
my Honda keys have never failed me.
Just replace the ignition switch to a universal one, Go to Napa they have different kinds
