Hi Everyone, I have done a pretty thorough search and have not found what I am looking for. I am building a 5.5, belt drive machine and the pump does not come with plumbing. I would like to run a buffer tank with a bypass line back to it, but am having trouble figuring out how to match the specs on an unloader valve to the pump. Any suggestions? Thank you!
Get a PA gear drive, forget about the belts. I have 2 and couldn’t be happier with them
Appreciate the advice, do you have a link for that as well?
You can get any go trapped unloader. The one shined up put up will be fine. As far as belly vs gear u cant help you I only run belt driven pumps I’m sure both work just fine
I have a PA B24 gear drive, doing my first oil change. Do you have the Quick Drain valve for it?
For how infrequently gear oil gets changed, I didn’t both installing one.
What size crush washer do you use?
I run a udor gearbox so probably not the same.
