Dewalt 3800psi Honda gtx270. Pulled fine 3 weeks ago. Tried to pull it’s locked up???
Pulled plug, no pull still. Any ideas? Help
Take the pull starter off and try and turn the crank over with breaker bar or ratchet. Also try the pull starter when off of engine. Report back with what you find.
Did u pull the trIgger on your gun to let pressure off the pump?
this is the most likely the solution. Try starting it with nothing connected to your hose, so essentially full flow out of your quick connect.
