Thanks again for all your inputs to my questions. It looks like the best way for me to clean roofs would be to use a surface cleaner with 1200 to 1400 psi. For you gents using surface cleaners for your roof cleaning, would you please recommend what poles you use and what I need to set up my 15"? My jobs will mostly be 2 story homes and I prefer not to walk on the tiles and would probably be fine with a 30’ telescoping rod. Thank you
Never going to work. Get a 12v system at a minimum if you plan in doing roofs
Sounds like a nightmare dude. Just gotta use bleach
