Hey yall, I’ve got a newbie question for you.
I have 2 4 gpm 4000 psi direct drive pressure washers. On my trailer is a 330 gal ibc water tote. Off of the ball valve is a 2 inch 90 degree reduced down to a garden hose fitting.
I am looking for advice on how to plumb both units which I will be running at the same time from that one water tote. I have tried to gravity feed them with no success. My intent is to feed each unit with 2 5.5 gpm water pumps. With that said, how would you guys plumb this? Can I go from the ibc tote ball valve into a Y then use suction line from there? Tia for any help you can offer!
