I had to put this down on paper (crudely at that) just to get it out of my brain so I don’t wake up at 4 am and think about it. By all means criticize and correct if you can actually understand it lol. My goal is to be able to use and clean all my tanks and pumps as well as fill tanks as needed while inadvertently having 2 soft wash set ups. Also having the ability to be versatile with my chemical.
Whoa. Idk. If you get a proportioner You don’t have to worry about transferring and it really simplifies things. Just pull bleach out of your downstream tank and water out of your water tank. Then just add a bucket with your roof soap in it. It’s much much much simpler than what you’re trying to do.
Idk I’ve thought about the proportioner and I dont feel like adding another toy this year. I’m sure it would make it a ton simpler though.
