Hello All…
I live in NJ. I washed some decks last year and now I want to go fully in the pressure wash business.
I have a van that I want to put a sysyem in. Where do I start and do you know anyone in the NJ that I can pay to set this up?
I have a tight budget so I don’t want to start the business in debt.
Welcome Ricky, You found the right place. Everything you ever wanted to know is right here at your fingertips. Just look for the magnifying glass at the top middle and type in any question you may have and the answers are there, you just have to read,read and read.
To add to what Doug said I would also research and figure out how to set your van up yourself. You don’t want to have a day or two of downtime every time you have an issue with anything. Pay someone to set it up and you might not know what to do to fix a simple issue. If it’s the busy season it might be sitting in the parking lot of the shop for a week until they have time to look at it. There are enough build threads on here to where you shouldn’t have a problem doing it. Start a build thread and just ask if you run into any issues.
What part of jersey are you in?
