I have found a claimed new, never used, Honda GX610K1 engine (18HP) on Facebook Marketplace.
The seller tells me he bought it new and it has sat in the box for minimum of seven years.
He tells me it has never been cranked, and he declined to put gas or oil in it to demonstrate that it runs.
I believe him that it has never been used (based on photos), though I am leery of buying (even a Honda) engine that has sat in a box for almost a decade.
Is this a safe bet, or a situation to sprint away from?
He is asking $750. My thinking is that I could get an extra 5 horses for essentially free if it’s a safe deal, as opposed to buying a new GX390 motor.
My intention is to pair this with an Udor 5.0 MC 18/20-GR pump as a versatile and small-footprint weekend warrior rig.
They usually don’t come with the operating level of oil in them. There will be some assembly lube from the engine itself being assembled at the factory. If the engine was in a non controlled environment for that amount of time (especially somewhere with higher humidity) without any type of vapor tech product in the crankcase oil, then more than likely some condensation has formed inside the crankcase and there will be some rust. If it was me and a good price for the engine I would buy it and disassemble it to double check everything is good to go. I have seen similar instances where engines have sat up for a long time and a valve was closed and it had enough rust on the seat it bent the pushrod before it freed up. Had to replace the pushrod, which was no biggie but could have been prevented by pulling the valve covers and doing a quick inspection.
It helps to squirt oil in the spark plug holes and then slowly turn the engine over by hand by either turning the flywheel or just turning the key a few times. This will lubricate the rings and cylinder walls since they’re probably bone dry from sitting for so long. If it’s a real old engine and, had a lot of moisture attack it, the rings can rust and seize up. Sometimes disassembly is required sometimes they’ll loosen up on their own. I doubt a brand new 7 year old engine has any issues though. If it does it should be an easy fix.
