Any suggestions for what to use to remove pigeon poop from concrete roof tiles?
Sent from my SGH-I547C using Pressure Washing Resource mobile app
How large of an area? Can you reach it or are you trying to inject and rinse?
Sent from my SAMSUNG-SM-G870A using Pressure Washing Resource mobile app
Its only a small area around 20 sq ft or so. I can get to it fairly easily. Was thinking of using a stiff brush on a pole to help then just a low pressure rinse.
I have the same thing coming up, but it’s a much bigger area (about 30 x 10) on the second floor of a house. I was thinking normal house wash, with extra Elemonator, but then pressure washing off instead of a soft wash rinse. Does that sound like it will work, or should I try a different chemical?
By the way, mine is on hardi-board siding, with a painted metal roof below, so I’m planning on a ton of rinse time.
Hot water is is effective at removing Guano.(fancy name for poop)
