Hello All,
First, thanks a ton to all of you who helped me put this build together. You may or may not remember, I was doing this as a part time gig to start. Well, I never got it off the ground because I have a new job. No down time with the new job, so all my hard work of learning how to put this together can now be someone else’s first setup, or maybe would work as a good 2nd truck if you are looking to expand.
I only have 6 hours on this engine! Really only used it for testing and playing around at my own house. All equipment is virtually brand new. I’m located in Indianapolis, IN. Would consider traveling up to 100 miles or so if someone is interested in the whole package.
My first choice would be to sell the truck and all equipment as a package. If I don’t find a deal there, I’ll break the equipment off the truck and sell things separately.
Asking $15,000 for the truck & all equipment listed below.
The Details:
2008 Chevy Silverado 1500 Extended Cab - 6.5’ bed
4x4
5.3L V8
162,500 miles
Clean IN title in hand
The truck is in good shape. Definitely showing it’s age a bit cosmetically. You’ll see some rust around both rear wheel wells & a little on the front rocker panels. Last winter I treated the rust with POR-15 and applied a bed liner material to try to protect it. Seems to have mostly worked well, although it is peeling in one spot.
Truck is mechanically sound. Service engine light has been on for at least 75,000 miles. It’s some emissions thing I’ve never fixed - don’t remember exactly what it was. Never had a problem with the truck at all. Did major service at 100k miles - plugs, all belts/hoses, all fluids, 4x4 service, etc. Not much since then, aside from routine oil changes. Tires are in good shape - would probably replace in the next year.
Pressure Washing Equipment:
Honda GX390 electric start (only 6 hours!)
Allison TSG-6835 pump - gear drive - rated 6.8gpm, 3500psi @ 1750 rpm
(with the 390 I’m seeing 6.5gpm @ 2300 psi)
K-7 Unloader
Hannay E1520 - 12” electric wind reel for pressure hose - fits 200’+ of ⅜ hose
Hannay E1526 - 18” electric wind supply hose reel - fits 150’+ of supply hose
55gal square buffer tank w/ Hudson float valve
35 gal round chem tank
GP stainless steel injector
150’ ¾ flexzilla supply hose on reel (100’ + 50’)
(2) 100’ ⅜ pressure hose on reel - 1 wire, 4000 psi, blue
(2) 50’ ⅜ pressure hose coiled in bucket as spare - 1 wire, 4000 psi, blue
Whisper Wash Ultra Clean 16” surface cleaner
Suttner ST36 sludge pump
(2) Suttner ST2315 guns
(2) 6” lance
36” lance
JROD w/ tips
Ball valve
Pressure gauge
Guy Blackmon shooter tip
Twist adjust tip
Misc. spares, fittings, quick connects, etc
7 gallons 12.5% bleach
Most of a gallon of Elemonator
Truck is equipped with ladder rack, one side tool box, exterior flood lighting. Lights, reel motors and the 390 are wired to a 125 amp hour AGM 12 volt deep cycle battery in the tool box (through breaker panel - see pics).
Thanks!
Bill
