@Racer yes, you will have sand everywhere you point. its quite messy.
And rule of thumb is @SchertzServicesLLC 1 pound of sand per square.
[quote=āSchertzServicesLLC, post:18, topic:23056ā] so if I donāt
want to sift it I just buy the media blast
[/quote]
Correct
Anyone use the arm and hammer products with their blasters? Very curious about it, better than sand all over too.
I have a blast cabinet in my garage for smaller items, but was looking at this vs vapor blasting
@Racer I get mine from Scruggs concrete its 3 bucks a bag. Little less if I buy a pallet of 50 lb bags. Itās fine sand no rocks or pebbles in it. If you get play sand it will have pebbles in it and stop your nozzle up aggravating! A 15 or 25 degree nozzle works best I hardly ever use a 0 degree.
@Racer last iron railing and furniture I did a few months back we used a little pot sander. Layed a tarp under the shed and kept vacuuming up the sand and pouring it back in the pot. Worked out great and was way cheaper than using the pressure washer. They have them @ harbor freight for under 100 bucks and they work great if u have a decent size compressor.
Give the job to a media blaster. This is what they do. And they are good at it.
Did you get that from Envirospec? See them in their ads all the time. You just drop the end in a bucket or bag of sand?
Iām looking to make this as quick & painless as possible. Can sit it out in yard. Just a table and 4 chairs. Getting real old using steel brush on my grinder.
Do they provide special tips or do you just use old pw tip you got laying around?
It takes 1/4 in screw in mega nozzles like the sludge pump. You can just stick it in the bag or use a 5 gallon bucket with the lid and drop the probe through the pour spout if u worried about the sand getting wet. You have to keep the draw hose above the gun or the sand will get wet and clogg the draw hose.
If you still have your 4 GPM machine it will work better more sand.
The city contractors around me use that āSand blasting attachmentā to remove graffiti on cement sidewalks⦠Never seen a sidewalk etched after there done⦠Looks like it works
Hell I have one sitting here on my desk⦠Need to try it
Thatās a big area. I would find a local striping company. They have walk behind and ones u ride they use to remove stripes. Would probably work great for that then he could come behind them and clean good for paint. Call them to come out and try a spot and just contract it out.
Thanks for the info
It doesnāt make a huge mess the medium is very fine. If you put tarp down itās just going to put holes in the tarp I try to hang what Iām working on. Harbor freight sells the small gun its gravity feed so definitely gotta shake it every once in a while. You may also want to look into walnuts may be a little easier on the metal
Iāve been thinking about having my backyard sanded anyway, Iāll just move the stuff around to the low spots and all the places my dogs have dug up, lol. Kill 2 birds with 1 shot.
There you go. Good thing about the pressure washing attachment is it is good for graffiti. Iām sure you will find other uses for it I keep a bucket of media and it on my truck these days
Yes sir . Little tip, Do not allow the sand to get wet, I put the sand in a five gallon bucket with a lid and screw cap. Take screw cap off ,put your suction tube in , Keep it away from your task at hand so it stays dry.
