Hello! I pressure washed my house and some of the oxidation was removed in a couple small areas. Will sunlight eventually re-oxidize those spots and blend it back in with the vinyl siding? Thank you for any replies!
Eventually…like several years. I’d recommend stripping the rest of the oxidation off that side and let it all build up again evenly.
Why are you pressure washing a house?
I used a jrod with low pressure soap tips and downstreamed the chemical. I didn’t put any real pressure against it
you got too close most likely, or you did have a stream and not a fan pattern.
To answer your question it will come back. How long? No idea, combination of sunlight and time.
