Owner
Hey guys im looking at cleaning some houses that are 3,000 sq. ft. plus and 2+ stories high,what are the longest wands they offer out there to clean with and which cleaner is best with cold water,plus if you have any other helpful hints they would be appriaciated.
        Thanks Greg Hatcher
        Elite Powerwashing
Do a search on this forum for House wash Mix, fresh wash or elemonator and you will answer every question you just asked. This forum is amazing and you can learn a ton in a short period of time just gotta read read and read again!
Britton Emerson
Victoria BC Canada
Emerson Exteriors O/O
emersonexteriors.com (name change so it’s under construction)
250-883-6067
You don’t need longer wands, just need the correct tips. Pressure Tek’s downstream nozzle kit will have the correct nozzles for your gpm. We have no problem reaching 3 stories from the ground with short wands. If the surface is brick then you made need to have more direct pressure or increase strength and dwell time.
The kit comes with 1 high rinse nozzle 1 low rinse nozzle and 1 high soap nozzle , 1 low pressure soap nozzle. Hope this helps, give me a call if you need assistance.
We use elemonator from pressure tek, and mix 12.5 sh 2 gallons and 3 gallons water in 5 gallon bucket. 5 oz of elemonator.
Matthew Adkins
Adkins Cleaning Solutions
336-338-8705
Greensboro, Nc
