Does anyone here run larger machines than 10gpm and have any recommendations? Looking for faster time then I can get with the igx800s
I’ve got the tsf2221. it just rinses faster imho. i can still get striping by going to fast.
sc will float.
Yeah I was looking for more gpm then 10 without running my two 10s tandem. I wanted suggestions for bigger machines
well. the mondo surface cleaner is rated for 12gpm. it can be modified to 20gpm. if they clean better with that gpm would be my question, obviously theres a speed factor with the increased size. would hoses be manageable with that much gpm under pressure?
What are you cleaning that you need that much? You can get bigger machines custom built, but why not run in tandem?
Heard bad things about running in tandem, ie pumps/unloaders blowing up. Cleaning couple million sq ft of sidewalk
One of our members here - https://www.youtube.com/watch?v=XlEXAeAq00w
What I’ve found is that you can get more production with 2 guys. One washing and one rinsing/or doing curbs and rinsing. Especially doing sidewalks. Parking garages, maybe different story.
What width are the walks? May want to invest in a sidewalk solutions machine - https://completesidewalksolutions.com/
3-6ft wide varying. Hose management becomes an issue running two guys. Moving the flatbeds every 15minutes with two guys hoses and chemical lines things get confused. Efficiency only goes up about 15% running a second machine
I have 12 we use for mini mondo.
Im having a mini built for 16 atm, how does it run with the 12?
I like it a lot
