I would start off downstreaming. I can get most stains out that way(patience and a few apps). I also use an xjet to speed things along. To make short work of it, do a 50/50 mix, in a pump up. You can also bump up the strength of your SH with a dash of sodium metasilicate or sodium hydroxide. They are both available at home depot. The blue all purpose jug for pressure washing contains sodium metasilicate. The zep purple power degreaser contains sodium hydroxide.
also I find you get better results if you pressure clean it first, and take the top layer off. I usually do that and downstream a mix on it , then go do something else while it dwells. Sometimes it takes a few apps, but if you wait long enough and don’t let it dry, it slowly disappears.
There are about 10 sets of stains so while one is dwelling I can be cleaning another section. I am just gonna bid it for a days work and if I get it great if not then maybe next time.
Sent from my SAMSUNG-SM-N910A using Pressure Washing Resource mobile app
