Now this house is quite old and I’m just making sure to do a good job. I’ve read it could turn it an orange hue and trying to avoid that, someone mentioned Prosoco or One Restore, would that be diluted quite a bit?
Not all limestone will turn orange, it depends on the iron content in the stone. I don’t really see much existing orange peaking out of that stone, so you may not have any issues.
I’ve mostly read to neutralize with oxalic acid if it’s turning orange.
You’re dead on @sixsolve . Nuke it @dcbrock . On some of those bad ones, will probably take at least a couple of coats, wait 5-10min in between. I usually just use a standard roof mix, about 3.5-4%.
Keep applying until the brown is gone… it may turn an orange hue, so don’t freak! That’s the detergent working…give it some time & rinse it out good…get as much off the stone surface, then apply again, & repeat…ect.
We use a 6% mix, best results are in high outside air temperatures.
