Not impressed/confused Whisper Wash 16”
Start at the top and go evenly side to side, working down the driveway. Not up and down :blush:
Helps to “cut in” the edges first too :ok_hand:t2:
I don’t use Facebook anymore, so I’m not sure if this link works, but by cutting in, I mean…
https://www.facebook.com/jetawaybusinesspage/videos/538420566365910?s=100004792697495&v=e&sfns=mo
Your link says it is damaged!
Thanks @Racer So you don’t even mess around with the 25025 tips?
@Patriotspwashing you said your 25025 tips are solid? Any marks like this ever? Thanks
No…I probably could go up a size, but never messed with it.
Looks good - I guess issue here is concrete was already damaged and that’s where the cream looked to be taken off. That’s why I went up a size thanks @Patriotspwashing
Granted, 5.5gpm…but no stripes.
I have to ask, what flow are you getting out of your pressure hose? Do you have a buffer tank?
Perhaps your nozzles are too close to surface. Adjust the height of the WW swivel.
I’ve been cleaning with about 2300psi with an Ultra Wash. I wash the concrete very fast even leaving a little dirt/mildew and then post-treat with an x-jet at 4% and it’s perfect.
Getting a little more more than 4gpm
I will have to give that a shot. Didn’t think of that
I think I recall IBS saying you can’t adjust them?
I think i remember that, Ill look.
Edit: Yea, doesnt appear its adjustible like my BE. It seems to me that the tip used has a tight fan pattern concentrating too much pressure in a smaller area.
Thanks for double checking
@Rammy1546…Psh
@dperez unreal…pssshhhh
Just yesterday I was doing psh to the wife she went cray cray on the 8th one. It was short lived…who get’s upset with that???
I’m surprised she made it to 8!
Try doing the “would ya just look at it” and she will definitely get irritated haha!
Only to be used in public for her maximum embarrassment
