Anyone use these yet?
https://m.northerntool.com/shop/tools/product_200756186_200756186
No mention of amps or psi rating. It’s not a transfer pump seeing as how it has a pressure switch on it. Come on NT
I looked it up, it’s for a water treatment facility.
So many questions. I wish it was atleast 5.5 gpm though. I would call them tomorrow but i dont want to be transferred to 5 different people before i can talk to someone who could answer maybe 2 questions i have
From what I can see in the pictures, the label appears to say 60psi/4.1 bar.
That would put its power requirements just a bit lower than the 5gpm/60psi Delevan 5800 series pumps.
I always wondered if two demand pumps could be put in parallel to increase flow. It would help that these ones have leak detection.
Two of these together might put out 6 gpm at the gun? They should at least put out as much as a Delevan Fatboy.
I wonder how much the replacement diaphragms are for these?
Edit:
@Grizz, I just found they have a 5.5gpm version:
https://m.northerntool.com/shop/tools/product_200756187_200756187
Edit 2:
Found the pump cartridges. They seem reasonably priced
https://m.northerntool.com/shop/tools/product_200756278_200756278
@Infinity I built a rig with two Shurflo 5059’s plumbed in parallel.
I have three 12v. One in service. I’ll probably give these a try when the time comes. Looks interesting. Leak detection is a major plus if it’s reliable. That’s always in the back of my mind when dragging around the hoses.
Same here. I have a Delavan ugpm and a NT 5.5 backup. I have another NT 5.5 that i use to transfer. When one of my NT goes bad ill grab one too.
Yeah, wish I had known about these 3 days ago before I finally ordered my Delevan 5800
Dudes! Stop wasting your time with 12v systems. Since I bought my 17 GPM system : 1/2" All-Flo Air Diaphragm Conversion Kit for 12 Volt pump Users, AFC5 I have never looked back. I swear that this is the sweetest thing since bear meat.
i KNOW YOU ALL KNOW HOW SWEET BEAR MEAT TASTES: JUST LIKE A $3000 JUNE DAY!![]()
Thinking about buying a gas system like ticks its a game changer.
Show that to our mentor @Racer and the student becomes the teacher.![]()
What’s the advantage of gas vs booster?
A gas power has to batch mix. Where a booster can be proportioned. At least that’s what the old trade off used to be. Somebody probably has came up with a way to “meter valve” a gas system by now
And then electricity, generator.
I’m pretty sold on going with a Dayton booster
Gas can have a proportioner too but it can over heat like a pressure washer without a bypass. Rick has his rigged up to let bleach or water in by turning ballvalves its pretty sweet.
I have that pump, absolutely love it, I just use it for the occasional roof or to pretreat concreate. I haven’t run 12.5% through it for transfer yet. I use air displacement to transfer SH from a 55 drum to whatever.
Do you rinse your ALL- FLO after transfer?
Looks interesting will watch it tonight.
I Do use it for 12.5% transfer and I do NOT rinse it out.
I hope to soon find a supplier that will deliver my SH from a tanker to my 250g tote(s) on a stand so that I can just let gravity do the transfers. I’m tired of messing around with drums.
I too am tired of the drum transfer and I’m a part timer, only about 2 drums a month. Ties up about 3 hours going to get it and the return. Delivery would be nice.
