I know it’s not much I’m only 15 feel free to criticize it.
Good job springing for quality reels and surface cleaner! If you’re specializing in driveways, I’d ditch the 90 going into the SC hub and just put a 2lb ankle weight around the hub. Like @MuscleMyHustle posted the other day, every time you let it rip you’re going to be torquing the front side of that hub, and weakening the plastic surround
Edit:. I take it all back, there’s a metal plate underneath it on yours. Some other models don’t have that apparently. Keep it up, you’re doing great homie
Great job! For 15 that’s awesome, go make some money.
Thanks so much
Great setup, only one question… who’s driving?
Me I have a restricted license can’t drive past 8.
That’s SO SLOW
Haha pm.
Looks good Field. Touch base with me Monday, may have a couple of houses in Anderson next week or so if you want to come over.
That would be great Ill talk with you then.
Once you get some experience, change the name. Don’t limit yourself to driveways only. What about walkways, sidewalks, patios, houses, decks, drive throughs! So much but the name limits you
@DJPWS I definitely agree I was scared at the beginning of screwing up houses but I’m doing everything now except roofs. I’m definitely going to change it next year. Any suggestions?
Where are you located again? South Carolina?
Don’t name it after your city, if u want to get into a diff cities market it will be tougher. I’ve learned my lesson on that.
