Newbie Surfactant Question
Hey all, just getting started with my operation. I bought a Softwash Starter Skid from Southeast Softwash that has a snazzy blend manifold for proportioning bleach and water from their respective tanks. I thought I’d also be getting plumbing to add a separate surfactant tank, but did not.
My question is now how to apply surfactant. My options seem to be:
  1. Buy a surfactant tank and try to plumb it with Southeast’s blend manifold so I can proportion it independently (cons are I have no idea how to do this)
  2. Batch mix the surfactant into the 50 gallon bleach tank. This was their recommendation, but from what I’m reading, the mixture of bleach and surfactant becomes useless after 24 hours. So to be efficient, I’d need to know EXACTLY how much bleach and detergent was needed for each job, then dispose of the extra solution every day?
  3. Apply it separately. I guess with a pump sprayer or otherwise. Would add an extra step and be clumsy applying two different solutions to a surface.
Feel like I must be missing something. Advice appreciated.
Get a good surfactant like elemonator, mix it in with the bleach, 1 Oz per gallon and you’re good. No, a good surfactant won’t go cause it to go bad after 24 hours. I’ve had it mixed up for a week or more and never noticed a difference.
I appreciate the response. Seeing some places that say the mixed solution will lose potency. ChatGPT says 24 hours lol but that didn’t make any sense given how pervasive the practice of batch mixing is. Hard to believe people are mixing new batches every day.
AI only knows what information it’s given, and there is a lot of bad information out there. The issue with AI is that it’s answers are always confident, even if wrong.
I know that Elemonator specifically advertises it’s bleach stable and I’ve found that to be true, at least in small batches.
Elemonator you are safe. I’ve used other surfactants and it turned to like a pancake batter consistency on the bottom and was all gross
