I have a Honda GX 390 with a bad pump. I have been told that the pump is beyond repair and needs replacing. Two recommendations are a Toolcy 4400/4.2GPM with a built in unloader or a Comet ZWD4040G with a VRT3 external unloader. I was also told I could add an external VRT3 unloader to the Toolcy along with the built in unloader. The unit will see very limited use (3 family members driveways possible yearly). Thanks in advance!!
If price is the same, go with the comet. If the comet cost more, go with the comet.
