Dark colors if we are to avoid these painted colors how do they get cleaned?
Yep and never again. I ended up going through my DI filter like water and have to replace it. The siding still had some dirt spots albeit I really didnât scrub that hard as I would a window pane. When I do window panes, I am doing lots of agitation, scrubbing same spot several strokes overlapping, and then rinse rinse rinse a good rinse. When I was doing the siding it was kind of like a a typewriterâŚlol
There are plenty of uneducated pressure washer companies or handy men out there. Let those houses be their problem.
Yep!!! It was still dirty!..lolâŚwhen I use my waterfed pole for window cleaning it comes out perfect. I use plenty of agitation, several overlapping scrubs, then rinse rinse, flush flush then rinse again. When I was doing the siding it was like a typewriter. I didnât really give it the same concerted efford, just a few swipes back and forth.
You sound like youâre a really good window cleaner. I suggest you stick with that. Canât be all things to everyone.
