Sorry if this is verboten, thought it looked interesting.
It’s a valve attachment that lets you dial down the pressure being sent to the nozzles while dumping the rest through a bypass hose into the surface cleaner cover. Doesn’t affect the pump.
I agree does look interesting and probably does work. It’s cool Its routed into the surface cleaner cover and not just on the ground. I dont know about you all but I generally dont have to change my tips enough to warrent installing a valve on my sc very cool idea though!!
Maybe, i can look at the concrete while dialing it down and see the change in pressure by the stripes, not enough just dial it back up. This is only with a 420cc motor, geardrive and 5.5 3500 pump, vrt3.
