Hi everyone I have a few questions I am located in sw Florida . Considering starting a small pressure washing business . At this time I want to only do small jobs flat work, small houses , pool decks, pool cages. Jobs that range from $150-500 dollars. No commercial or roofs. What is the market like do you have to do roofs ? Also what about timing with all going on in the world do you think it’s hard starting right now?
In regards to the timing yes I think starting a new business would be challenging right now. You’re not eligible for any SBA loans based on not being a business before Feb 15th 2020 (not sure if this applies to you).
Thanks for the input I forgot to mention I am a career firefighter so I would be doing this on my days off . I stopped by my local pressure washing shop and got a price for a nice portable unit, hoses, surface cleaner and down stream equipment. Around $2,600 dollars then I was going to get a truck cap for my truck to put the equipment in.
Thank you for your service. Welcome to the forum. What kind of machine are you looking to start with?
It’s not impossible to start now it will be a little more challenging, you will find that marketing will have to be a little more aggressive due to people sitting on there dollars till this mess blows over.
The hotsy dealer in my area recommendations was belt drive, I think 4200 psi 4 GPM. With a eagle 200 20in surface cleaner. 100 feet of non streak hose, Down streamer , ball valve , and 2 5 gallon bleach containers. Can’t remember the name of the unit. Again I am wanting to do small jobs .
Belt drive was a good suggestion, 100 feet of hose won’t get you very far though. 200 feet of hose will be sufficient for 96% of residential. Unless you want to lug around your unit through customers property (not fun). With a 4 gpm machine I wouldn’t purchase a surface cleaner over 16”. Even with a 16” surface cleaner you’ll want a pump up sprayer to post treat bad concrete. Good luck and thanks for what you do.
There’ll be a few additional items needed; a backup DS injector for sure (they go bad wo warning). I believe there’s a recent thread with a start up list. Thanks for your service!
Thanks for the reply’s I know In sw florida the competition is all over. I was going to have a minimum of $150 dollars to come out. I am trying to do 5-10 jobs per month.
Where in SW Florida are you. I am in North Naples, Bonita Springs , South Fort Myers area. And it is end of the season ( early end because of virus ). 99% of my customers are part time residents , and the are going back up North. Also most gated communities dont let contractors in, only for emergency.
I get my pressure washers from Hotsy in Fort Myers or Proline equipment in Naples, all other staff online.
i don’t wash roofs because of GL and Work comp insurance price. I do loose some jobs because of that , most people want whole package ( roof, house , pool cage deck and driveway ). I am staying busy enough doing driveways , pool decks and enclosures.
like it was mentioned get extra DS injector and different size and pattern nozzles, learn downstream .
Good Luck.
Thanks for the reply I am in fort Myers wanting to only do my work in Lee county. How do you like the pressure washing shop in fort Myers? That’s who I talked to about equipment.
I’ve been using them for 15 years good service and professional but high prize. I try to buy pressure washers locally but every thing else online. My last 8gpm and 5gpm i got better deal in Naples at proline.
I have 5gpm , 3k psi pressure pro set up in my truck bed. If you want to check it , i live in San Carlos park.
Write now we are pretty busy with our janitorial service , I hope things get back to normal soon. You are welcome to call or text me. Vladis 239-357-9083
Thanks
