Hey guys,
Just setting up a new soft wash set up and have some questions… 1st. Is a Seaflo 5.5gpm /60 psi too small to get it done? 2nd. Is 200 ft of 3/4 inch hose too big for this setup? I think applying the chems will be ok but dont think my rinse will be strong enough.
Most of us downstream.
And most of us have a 12v pump, realize it has its uses, but still downstream.
An 8 GPM pressure washer is the sweet spot for softwashing
3/8 hose is all you need.
8 gpm? I had an 8 gpm machine and it seemed like it wasn’t pulling SH very well with an 8 gpm injector. Do you do anything different with injectors or whatnot? (Not a challenge, I trust your experience far more than my own. Just not sure what I might’ve been doing wrong since it felt so diluted.)
Most of us use a 2.1 or you can even go to a 1.8 if you need it really strong.
What Rick said. He must have got up to pee also
2.1 works fine once I figured out how to eliminate air suction leaks in my setup.
But to answer OP’s question try to go with the 7gpm.
