Looks good, one suggestion though, make sure the gas tanks are on the same sideas the truck’s fill cap
Also I’ve noticed some trailer builds where they put the nuts on the top side, so the bolts come from under the bed (with washers) to hold down reels and stuff. This would allow you to see if it comes loose easier i suppose
A lot of times is because there is not enough clearance to put the bolts in top side
Amazing, I’ll take a video tomorrow. Haven’t done a bucket test yet. Washed a few houses with it.
I would guess it’s putting out more then 7gpm, and I have no concerns with a 16in sc.
May I ask why you have the reels at different angles?
The main reason was because they fit best this one. The second reason was because this was built mainly for a 2 man truck. One guy pulls one direction around the house the other guy pulls the other. Before when pulling to one side with the reel being straight we would have the hose hop over the sides of the reel and get stuck on the swivel and have to walk back!
