What are you using that tank for. I’m assuming just a buffer tank
I’m gonna run two 4 gpm machines off it most days where one guy does one side of the house and I do the other. If there is concrete I’m gonna use the Siamese kit to speed that up. Which will be very few and far between. Would have got an 8 machine, but I can’t afford two…
But you are using it as a buffer tank not a sole supply tank
Yes this is a buffer tank. I have no need to bring a supply.
So you are using house water as a supply
Yes I use the water supply at property I am washing
Slide the bulkhead fitting down a broom handle and pull it though the hole.
Yes a broom handle or paint pole works well for this
Wire is much more flexible
