Hey gang!
I’ve recently discovered this site and enjoy reading/learning from each and every post.
A little bit about me.
They call me PuJo around these parts. I am a life long oil field worker in the Gulf of Mexico.
I work a 14 on and 14 off rotation. Having 14 days off at the time, I have been cutting yards, bush hogging, and whatever else I could find to do around the area. I was looking for a pressure washer to buy for personnel use and thought that maybe is I get one big enough, I could make a few $$ at the same time. Well, that was before I found this site and made the purchase. I ended up with the SIMPSON Cleaning ALH4240 Aluminum Gas Pressure Washer Powered by Honda GX390, 4200 PSI @ 4.0 GPM. If I would have found this site prior to my purchase, I would have went with a belt driven unit.
Oh well, I guess I will just have to learn on it and build it up to an upgrade!
My goal is to have a second (third) job power washing homes in my area as well as building a trailer to haul it all around on. I am not a fan of the pick-up truck skid.
There is only a couple people power washing in the area and it seems like I could do well with it here in the central Louisiana area.
Anyway, I can ramble on but that’s enough for now.
That’s good to know!
I was kicking myself for purchasing before researching!
Any idea as to how much suction pressure this pump has when running a bulk tank?
Reading and learning, if my thinking is correct, when you say “cool the pump”, you are referring to plumbing the unloader valve to the buffer tank? If so, my Simpson ALH4240 Aluminum Gas Pressure Washer/GX390 doesn’t have an unloader that I can re-plumb. So is that something I would have to replace with a different style or something?
