Gotta agree with the above. If you caused this damage with a pressure washer - that you did 2 passes with - you have the smoothest, straightest strokes on the planet.
I get blamed (rarely) for what others do, such as painters using sandpaper on french windows with resulting scratches. Just because you clean something doesn’t mean the surface was created perfectly.
Hi! To find out what I can do, say @discobot display help
I doubt you removed the cream unless you washed it before 5 days of cure. Your driveway looks fine to me and you’re investment is not going down the drain. It is as the other fella said a broom finished job.
@discobot Fortune
Edit:
Its a year old post. His driveway is probably carved down to bedrock by now.
Ah good catch on the necro thread.
Thank You all for your feedback on this. It had definitely put my mind to ease. Much appreciated!
