Anyone have a trick to get pvc pipes laying on the bottom of a 275g tote? I use them to hold the draw hoses down and they fell off. Happens every year seems like. I don’t feel like spending the next hour with a coat hanger or wire trying to retrieve them.
Long senior citizen gripper doodads?
Home Depot has a 36”
Thanks. I can’t believe i didn’t think of that.
Coat hanger will work too, just hook it around neck
dollar tree had those DOODADS. But they are weak, so if needing for maybe more than a handfull of time, dont get dollartrees.
Yep, stick, coat hanger and tape, gets almost anything from anywhere. Although wire hangers seem to be harder to find nowadays that everything is plastic. I have a stash of them. They make those worthless plastic hangars with just a bit of a metal hook.
I used a coat hanger in the past but it takes me a while and quite a few curse words to finally get it out.
