They are not exterior grade doors. MDF/pressboard soaked up water like a sponge. You have insurance? Even tho you should have every reason to believe the house is built correctly.
Idk how you can be held liable for improper construction. There should have been no reason to check the door material imo. But what do I know, its 2018 and everyone is entitled to what someone else “owes” them.
If they are hollow core they are interior only. No way you should be held responsible. If it wasn’t you, rain would have done it. Worse comes to worse replace them yourself with the same door. Its easy to do with just a few tools slabs here are 70-80 bucks
Right, replace with like doors. Can’t cost all that much. Get with a contractor and get it in writing the opinion that exterior doors are supposed to be hardwood or steel, not that MDF stuff.
MDF doors are only $50-60 from Bunnings, get a local handy man to install them, next time they get wet it will happen again. Those are clearly internal doors, do they have a large patio or something so they don’t get weather?
Hi @steve076 I can’t find an external door at Bunnings with a pattern like those. Just plain.
I can’t replace them with internal doors either. That’s false economy and a waste of time. I have some loyalty to the customer and it wouldn’t sit right with me doing it that way when I think about it.
Cheers
Think I’ll have to talk it out with them. Yes, the damage is done, but what could I have done to prevent it? Nothing.
