Off my 5.5 gallon per minute pressure washer what is the smallest spray tip I can use that will still pull soap and I can reach the highest levels? Can I still pull soap with a 0030 or does it have to be a 0040?
I use an M5 twist
Probably 0040
Depends on the injector. If you’re using a 2-4gpm injector, a 0030 would probably work. Move up to a 3-5 gpm ds, and you might not be able to pull with a 30.
But my 0040 works great on my 5.5 machine for soaping and rinsing as high as 35’ (I go back to the truck to turn off the soap)
