I was given a mosmatic surface cleaner, and when i used it, i noticed that a large amount of water was spraying out of the weep holes on the top of the cleaner (i think its the swivel?). I read that a small amount of water should weep out of those holes, but on mine it is spraying a huge amount out.
Can i repair or replace that part? I’ve included a link to a picture where i have the holes marked. I believe it is a 21" SC.
Also, the two tips are ground down pretty bad. Could someone recommend the proper tips i should be using on it? My pressure washer is a dewalt 4gpm, 4200 PSI unit.
Thanks for any help!
