MI-T-M VS Shark Pressure Washer
Hi everyone, my question is which pressure wash is better? Im planning on doing commercial shopping centers and restaurants garbage areas. Both are 3500 PSI and 5.6 GPM the shark doesn’t have a generator and it only has a 12V burner. Thanks in advance.
Generator outperforms 12v any day. Only con is less fuel effecient
In my experience theyre pretty similar machines. Ive used both when renting machines from local rental shops. Look at the the parts. What kind of engine and pump are they using, less important but the other major detail is the unloader. I’m assuming at that gpm that they’re both belt driven but that’s another major factor. Other than that the type of coil in the heater is another thing to bloom for. Ill say neither is a high end brand but I dont have any high end machines and they work just fine. I use pressure pros in case you’re curious.
Thank you guys . I think I’ll go with the MI T M.
