Pictures on here may help. 9 times out of 10 this is usually an unloader issue. I don’t know what unloader you have but you can back it all the way off (usually counter clockwise) and then do ~10 “turns” clockwise to get you close. Those are not full turns just grasp it and turn like you’re turning on a faucet.
Please do not think I am an expert. I’ve just done this a lot in this past where the nearest town was hours away and I was the closest thing to an expert for at least 200 miles.
After you get this figured out you’re going to want to run your bypass hose to your buffer tank. Otherwise, you’ll have to be on the gun all the time or walk back to your trailer to shut down the machine if you’re not going to be spraying for anything longer than a minute. Please post some pics so we can get a better idea.
This times 10. The amount of pressure building up inside that pump is astronomical. Consider how much psi is in a semi tire. When one of those things blow you know it. Multiply that times like 4000
When the spring was in, I noticed how the unloader vibrates when engine shut off. With the spring out it still shut off but not as aggressive and little to no vibration
