So today I was washing and my machine started acting up. At first I felt some vibration in the hose/gun and some surging. Then i started having a loss of pressure and flow.
It got to the point where I couldn’t even clean anymore.
No leaks. No air getting in.
Is the pump shot??
I threw my spare on but it’s a 3.5gpm/4k
I was using a 4gpm.
Will my tips on my gun and surface cleaner still work well tonorrow?
Was using 4.0 for softwash and 02 on my surfaces cleaner.
If you are referring to Jrod tips, they will work but there might be a loss of height and pressure. The surface cleaner will work but not as well. Just be sure to pre well and post treat. That should help make up the difference. I don’t think it will be a huge loss.
Thank you! That calms my mind some. I’m fine with going a little slower or busting out the 10ft a-frame if I have to talk peaks for a bit till i fix this.
I was using the j rod softwash tips, and pressure tips at 1200psi on my 4gpm.
Thank you all for replying!
So my back up 3.5gpm worked well today.
The surface cleaner still hovered, and I could softwash, albeit less pressure and r
Get you a new unloader and try it, there’s no need to try and fix it, those unloaders are like 50 bucks. If it doesnt fix your problem then at least you have a spare for when it does mess up
