Has anyone here successfully disconnected a low oil sensor from a gx690 so there will not be any issues moving forward?
Disconnecting the wire from the sensor is no problem. But Im hearing you need to actually bypass the wire and not just disconnect it from the sensor or it will continue to shut off.
I have not done this myself, but looking at the gx690 workshop manual, page82(ignition system), the oil switch simply connect the yellow wire to ground.
