That video will get someone killed. Never ever let go of the trigger once you start the machine with a new unloader. A gage should not be used. Install unloader. Squeeze trigger and do not let go. Adjust unloader until only a small trickle of water comes out the bypass. Use the correct red tip matched to your machine
I was trying to look up advice on a quality unloader. I did find this though. I have just one question being as the video was no longer available that bystander was referring to. What’s the rest of the process? I’m sure I will be purchasing from pressure Tek along with an unloader block today. Would you guys recommend any other machine saving pieces? I have a 5gpm machine.
That’s pretty much it. Tighten up the nut to the unloader if has one and you’re properly adjusted. There’s no need to touch it again unless you suspect you’re having problems with it and need to adjust it again.
