For yall who have a k7 unloader, when you use soft wash tips is the pressure hose limp? Did bucket test and it’s where it needs to be as far as volume. Just weird. Today was first day we used it.
Yup, shocked me too. Let off the gun and no pressure in the line. There’s very little pressure in the hose when you softwash anyway, maybe what…60psi?
It’s nice. I like the new setup. Makes the hoses flex more violently when going into bypass mode that is.
General pump flow unloaders carry about 75 psi on the outlet side. When you open the outlet this loss of pressure is what deactivates the bypass
