I didn’t know that about the direct drive machines I’m glad you mentioned that because I was honestly gonna get set up with the tank even if I go with the 4gpm unit that way when the upgrade comes I’ll be able to just swap out units as opposed to building a whole trailer with jobs waiting.
You guys have any thoughts on this setup.
Most people will tell you to stay away from kits like that. You end up buying stuff you don’t need. @Infinity Alex posts often about a good setup to start with. I think this is it EB5525HG 5.5 GPM @ 2500 PSI GX390 Honda GP Pump. This is honestly a good place to start for a beginner machine. Then buy the other little things you need through the winter so you will be ready to rock come spring time.
