Yup, I find that over priced tbh, ever flow 5.5 on amazon and 200 ft of hose should only run you $350. Jrod another $50
I would try and find a washer with a different pump.
Keep in mind that if you don’t use a buffer tank you can’t let off the trigger for more than like 30 seconds. If the homeowner comes out to talk to you you’re either going to have to keep pulling the trigger in between sentences or shut your machine down. Same goes for if your phone rings and someone is talking to you about a job. I don’t think I could wash without a buffer tank.
What type of pump is good ?
Also I should be forming my llc in the winter when is a good time to start booking jobs for the spring , of course I’ll be booking before I buy my equipment i don’t know if that is a start way to do it tho .
