Is this RX705 pump for Be 7.0r Slavageable?
Hello Everyone.
I found a Be 7.0r 3100psi pressure washer out for garbage and I’m wondering if the pump is salvageable or if it requires a new one.
As you can see from the photo, the the seals on the right and middle are blown. Also, the corresponding pistons on the right and middle show wear…which I’m assuming may cause friction and would cause new replacement seals to malfunction also.
Does anyone know how easy it is to source the seals and pistons/replace them and if it is worth it, or given the condition you see in the photos, do you think a new pump is warranted? I already have a working pressure washer…but this one is heavier duty I believe…so I’m interested in making it functional if I can do it in a cost effective manner. Thanks in advance for your help.
-Chris
That’s a throw away pump.
before or after the blowout? :joy:
Ha! Ok, thanks guys. I appreciate the feedback. I won’t waste any time with it.
-Chris
