Pa homes I’m noticing this stain under the eaves. Is this what is known as fallout? Any better explanation I can give to a customer other than it doesn’t get rained on? Does anything remove it?
Ds straight sh 1to15 with elemonator 2oz per gal of sh I soaped this side twice didn’t make a difference up top.
Use a degreaser on fallout. There are a lot of good threads about it on here.
Degreaser for fall out. Typically it’s not included in a normal house wash.
1 to 15 SH wont cut it. I break out my 12V and hit it with about 3-4%. That usually does it for me.
I believe a couple other guys mentioned oxalic will take it right off. I’ve been somewhat fortunate, most seems to come off with a couple applications of housewash mix…although there was this one house a couple years ago.
I tried purple power scrub dwell rinse no luck then oxalic scrub dwell rinse on the dirty spot in the second picture with no luck. Sounds like I need a better degreaser. I swore I searched fallout on here and didn’t see much now I search it and there’s plenty of stuff to try
I’ve tried Red Raider degreaser straight, and a bunch of other things. One Restore has been the only thing that has ever worked for me consistently.
OneRestore worked for me. Red raider if it’s real light staining.
Fallout thread and lots of help thanks guys. should get you that thread.
SH-Elemonator-Degreaser Mix in a bucket down streamed… no scrubbing required
Chesebro Which degreaser do you mix with sh and elemonator?
