For water to be coming out the whole time?
Looks like your thermal relief was used and needs to be replaced.
Do you run a buffer tank? What is your machine?
No I don’t have a buffer tank. It’s a Honda Gx390 4gpm 4000psi
Likely you were off the gun too long and tripped the thermal relief valve. Can order a new one and replace it.
Do yourself a favor and get a 30 gallon buffer tank. Right now you’re needing to pull the trigger at least every minute to prevent the pump overheating.
