I don’t know if anyone can help with this, but I have an IPC Eagle Hydro Cart for wfp window cleaning. I went to change the DI filter the other day and the houseing won’t turn no more than a 1/4" or so. I usually change it 2 times a season, and never had any trouble before. I’m affaid I will break the plastic wrench if I force it too much.
Any suggestions? Maybe PB Blaster? Lol! Not sure that would be good on plastic.
[MENTION=7652]gbran[/MENTION]
Greg it probably went on a little of balance and is kind aout of the threads. Do you have that wrench that came with it?
[MENTION=1]Chris[/MENTION]
I bought the equipment used, so I’m assuming it’s the correct wrench. Black plastic and goes all the way around the canister. I used a rubber mallet to tap on it a few times, but no luck.
Greg give us a call at 862-266-0677
Ask for Alex, he should be able to walk you through getting it apart.
Try on or WD-40, you just need something to lube the seal to break it loose. I’ve been a Nissan tech for 10 years and use it on seals and plastic all the time with no problems.
